QueryByRect problem in PHPmapscript
Bill Thoen
bthoen at GISNET.COM
Thu Nov 1 11:52:14 EDT 2007
Ah HA! I just clued into the fact that the parameters for getShape() are
in the opposite order from those in getFeature(). Doh! When I pass them
in the proper order getShape works fine. Damn computers; they're just so
picky about the details...
Steve Lime wrote:
> Keeping the SWIG and PHP versions of MapScript sync'd has always been a challenge so it's possible
> it didn't get added until 4.10.1 or later. At 4.10.0 you should have getShape which works the same
> as getFeature (they wrap the same C code) but with getShape you must pass a tile index in addition
> to the shape index. Usually it's just:
> $shape = $layer->getShape(-1, $shpindex);
> Steve
>>>> Bill Thoen <bthoen at gisnet.com> 10/31/07 5:48 PM >>>
> getFeature doesn't seem to be defined in version 4.10.0. When I try to
> use it I get an error message that says it's undefined. Is this a recent
> change, or should it be there?
> Steve Lime wrote:
>> getFeature is the method to use to retreive a feature from a layer. It is a layer method and
>> exists for both PHP and the SWIG-based bindings. It replaces the getShape method which
>> I created with stupid parameter orderings that made it impossible to not pass a tile index.
>> I see that it is missing from the PHP/MapScript docs but is present in the Swig docs. I'll file
>> a ticket on that one... There's already a note at the bottom of the page but it hasn't been
>> noticed.
