AGG line offset problem
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Fri Nov 2 04:27:00 EDT 2007
Luis González Medina wrote:
> I really appreciate if you can help me with a problem with OFFSET feature when I use AGG/PNG output format in Mapserver 5.0.
> In Mapserver 4.x I used OFFSET x -99 in the STYLE section on my Mapfile for do displaced lines that follow the same direction of the original line:
> LAYER
> TYPE LINE
> CLASS
> STYLE
> SYMBOL "circle"
> COLOR 180 180 180
> SIZE 3
> OFFSET 5 -99
> END
> But using Mapserver 5.0 and AGG/PNG output format, this feature doesn't work.
Luis,
some time ago there was a post by Thomas Bonfort to this list that
explained in great detail how to do this with AGG. You can find it here:
http://lists.umn.edu/cgi-bin/wa?A2=ind0708&L=mapserver-users&T=0&F=&S=&P=57127
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web: www.territoriumonline.com
