Class or filter expression on date field in shapefile
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Fri Nov 2 14:02:09 EDT 2007
Ei Fujioka wrote:
> What is the date format for class/filter expression?
> I use Mapserver 4.2.
> I tried the following expression but failed.
> EXPRESSION ([DATE_S] > '2003-01-01')
Ei,
I happened to stumble upon some MapServer 4.2 code today and a quick
look at the lexer and parser made me think that the following expression
might even work:
EXPRESSION ('[DATE_S]' > '2003-01-01')
Note that it was single quotes back then, not backticks, and the field
needs to be quoted too. Besides, YYYY-MM-DD seems to be the only
recognized format, any other character combination is treated as a
string. I wasn't able to actually test this, though, so take it FWIW.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web: www.territoriumonline.com
