SLD resquest issue with EXPRESSION parameter
Jacolin Yves
yjacolin at FREE.FR
Sat Nov 3 05:41:54 EDT 2007
Thanks Yewondwossen Assefa,
One more question, do you know some issue with the EXPRESSION parameter (for
instance a simple EXPRESSION ('[ZONE_]' eq 'UCa')) AND the number of CLASS in
a LAYER?
My problem is that the GetStyles request send back an empty xml file with
EXPRESSION and if more than 6 CLASSE objects are used.
If I coment all the EXPRESSION, I get an XML file. Actualy, if I uncoment
EXPRESSION in more than 6 CLASSes, the xml file will be empty.
Furthermore, even if I get an xml file, it seems there is a problem in my XML
data :
<ogc:Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>ZONE_</ogc:PropertyName>
<ogc:Literal></ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
Or for one of them :
<ogc:Filter>
<ogc:Literal>��p �$~����� </ogc:Literal>
</ogc:Filter>
As you can see, the Literal properties is empty or unusable :(
Tthe FILTER parameter doesn't seem to be usable for the GetStyles request. Am
I right?
Best regards,
Y.
Le Friday 02 November 2007 20:45:46 Yewondwossen Assefa, vous avez écrit :
> Hi There,
> I have entered a bug regarding this at
> http://trac.osgeo.org/mapserver/ticket/2380. Only one level of logical
> expression ( A AND B) was initially supported. It should be possible to
> extend it to support several levels using para theses (something like (A
> AND B) AND (C).
> Best Regards
> Jacolin Yves wrote:
> > Hi list,
> > I am using Mapserver as a OGC webserver. I am trying the GetStyles
> > request and find some issues. Someone asked about this issue in the
> > mailing list in the short last few monthes.
> > I got some LAYER which contains about 12 CLASS objets, this CLASS
> > contains EXPRESSION parameter. Here an exemple :
> > CLASS
> > NAME "M1 : La Défense - Château de Vincennes"
> > EXPRESSION ('[TYPE]' eq 'M' AND '[NUMERO]' eq '1' AND '[DATE_LIV]'
> > < '200712')
> > COLOR 255 255 0
> > SIZE 3
> > SYMBOL 1
> > END
> > There are 24 class like this one.
> > If I try a GetStyles request on this kind of layer, nothing occurs (ie
> > blank page), if I remove most CLASS the XML response is displayed, If I
> > remove only the EXPRESSION parameter, again the XML response is
> > displayed. So I think the issue is not link to the number of CLASS
> > object, but rather with EXPRESSION parameter.
> > BUT, in an other LAYER, I got only three CLASS object with EXPRESSION
> > parameter, and the xml response is displayed.
> > Finally, it seems that if a LAYER got a lot of CLASS object with
> > EXPRESSION parameter inside, the XML response failed. And if a LAYER
> > object got a lot of CLASS object, the XML response failed as well.
> > I am using Mapserver 4.10. Are someone aware of this issue and know a
> > workaround.
> > Thanks,
> > Y.
Yves Jacolin
http://softlibre.gloobe.org
