Mapfile classes
Todd Harris
Todd.Harris at LANDGATE.WA.GOV.AU
Mon Nov 5 04:47:41 EST 2007
Hi all,
In a mapfile, using classes, is there any way to ensure that the correct
polygons are displayed last (ie: on top). I assumed that the last CLASS
listed would always display on top but I've found that is not
necessarily the case.
I have multiple classes that have overlapping polygons required to be
filled and displayed in the correct order.
Any suggestions would be appreciated.
Regards
Todd Harris
Geospatial Product Consultant, SLIP GIS Support
Information Management Division
Landgate Western Australia
(08) 9273 7866
www.landgate.wa.gov.au
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged, in which case neither is intended to be waived or lost by mistaken delivery to you. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this e-mail in error, please notify the sender by return e-mail and delete the message and any attachments from your system. Unless specifically indicated, this e-mail does not constitute formal advice or commitment by the sender or the Western Australian Land Information Authority (Landgate). Information in this message not relating to the official business of Landgate shall be understood as neither given nor endorsed by it. It is your responsibility to check any attachments for viruses and defects before opening or sending them on. Landgate’s liability is limited to re-supplying affected attachments.
