Mapfile classes
Bart van den Eijnden
bartvde at GMAIL.COM
Mon Nov 5 05:23:42 EST 2007
Hi Todd,
you will need to sort your data, for shapefiles you can use sortshp.
http://mapserver.gis.umn.edu/docs/reference/utilityreference/sortshp
Best regards,
Bart
On 11/5/07, Todd Harris <Todd.Harris at landgate.wa.gov.au> wrote:
> Hi all,
> In a mapfile, using classes, is there any way to ensure that the correct
> polygons are displayed last (ie: on top). I assumed that the last CLASS
> listed would always display on top but I've found that is not
> necessarily the case.
> I have multiple classes that have overlapping polygons required to be
> filled and displayed in the correct order.
> Any suggestions would be appreciated.
> Regards
> Todd Harris
> Geospatial Product Consultant, SLIP GIS Support
> Information Management Division
> Landgate Western Australia
> (08) 9273 7866
> www.landgate.wa.gov.au
> This e-mail and any files transmitted with it are intended only for the
> use of the addressee(s). It may contain information that is confidential and
> privileged, in which case neither is intended to be waived or lost by
> mistaken delivery to you. If you are not an intended recipient, any use,
> interference with, disclosure, distribution or copying of this material is
> unauthorised and prohibited. If you receive this e-mail in error, please
> notify the sender by return e-mail and delete the message and any
> attachments from your system. Unless specifically indicated, this e-mail
> does not constitute formal advice or commitment by the sender or the Western
> Australian Land Information Authority (Landgate). Information in this
> message not relating to the official business of Landgate shall be
> understood as neither given nor endorsed by it. It is your responsibility to
> check any attachments for viruses and defects before opening or sending them
> on. Landgate's liability is limited to re-supplying affected attachments.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071105/b21f379c/attachment.html
