Mapserver and MySQL
Frank Warmerdam
warmerdam at POBOX.COM
Tue Nov 6 09:16:29 EST 2007
Vishal Nagpal wrote:
> Hello Everybody,
> I am trying to use MapServer to read MySQL spatial data but it is unable to
> open the database.
> I tried to use ogrinfo MySQL:test user=mysql tablename -so
> But it gave a message that unable to open with existing drivers,
> I am working pretty fine with POSTGRES, DGN and DT2 layers
> is it possible that i have missed out on some steps in installation of GDAL/OGR,
> Also I tried to use ovf files but there too I faced the same problem,
> Some of the examples of ovf file use
> ODBC while others use MySQL
> which one to follow, is it OK to use either,
Vishal,
The MySQL driver is not built into OGR by default. Did you build GDAL/OGR
from source yourself? Did you explicitly configure in Mysql support?
OVF (VRT) files are normally used when you use a mysql table through odbc
that is not using spatial data types. The OVF file tells OGR which columns
are x and y.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
