Mapserver and MySQL
Murat Beyhan
beyhan at DEPREM.GOV.TR
Tue Nov 6 03:39:05 EST 2007
Dear Vishal try to do following if you use LinuxOS in the console
ogrinfo --formats
Supported Formats:
ESRI Shapefile
MapInfo File
UK .NTF
SDTS
TIGER
S57
DGN
VRT
AVCBin
REC
Memory
CSV
GML
OGDI
MySQL
you will see the list of the supported formats.
If the MySql doesn't listed on the list you must reinstall ogr
application by using MySql support
I hope it will be help you.
Regards
Murat
Vishal Nagpal wrote:
> Hello Everybody,
> I am trying to use MapServer to read MySQL spatial data but it is unable to
> open the database.
> I tried to use ogrinfo MySQL:test user=mysql tablename -so
> But it gave a message that unable to open with existing drivers,
> I am working pretty fine with POSTGRES, DGN and DT2 layers
> is it possible that i have missed out on some steps in installation of GDAL/OGR,
> Also I tried to use ovf files but there too I faced the same problem,
> Some of the examples of ovf file use
> ODBC while others use MySQL
> which one to follow, is it OK to use either,
> Help?
> Regards,
> Vishal
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
