mapscript, setSymbolSet and asp.net
Daniel Morissette
dmorissette at MAPGEARS.COM
Tue Nov 6 11:14:55 EST 2007
Stéphane COLZY wrote:
> I’m using mapscript c# with asp.net
> I get this error when calling mapObj.setSymbolSet(filename) several times:
> /loadSymbolSet(): Unknown Identifier. Parsing error near (S):(line 0)/
> first call is ok and symbols are showing correctly, but when I try to
> load another map with the same symbolSet file it fails and I need to
> restart the asp.net process to make it work again.
Which version of MapServer are you using? I'd suggest you try again with
V5.0 if that's not the version you are using. There is at least ticket
#2021 which has been fixed in 5.0 and that may (???) be related to the
type of problem you have encountered:
http://trac.osgeo.org/mapserver/ticket/2021
Daniel
Daniel Morissette
http://www.mapgears.com/
