mapscript, setSymbolSet and asp.net
    Stéphane COLZY
    stephane.colzy at MAGELLIUM.FR
    Tue Nov  6 08:04:23 PST 2007
Im using mapscript c# with asp.net
I get this error when calling mapObj.setSymbolSet(filename) several times:
loadSymbolSet(): Unknown Identifier. Parsing error near (S):(line 0)
first call is ok and symbols are showing correctly, but when I try to load
another map with the same symbolSet file it fails and I need to restart the
asp.net process to make it work again.
Im not sure this is related to bug #339 which has been fixed a long time
ago.
Ive seen several related posts, I know the workaround is to create symbols
directly in the code but still this is really frustating
stephane
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071106/4af77daa/attachment.htm>
More information about the MapServer-users
