PostGIS Queries using FILTER
Kyle Wilcox
Kyle.Wilcox at NOAA.GOV
Tue Nov 6 17:00:21 EST 2007
Did the usual searching without finding anything relevant.
The application I am referencing is at:
http://155.206.18.162/mapping/map/map.phtml
I have time series data in a PostGIS enabled database (current and wind
fields from model output). I can display the point data without
problems (try any of the current or wind layers).
The problem is that when querying a point layer, the data that is always
extracted from the first timestamp rather than the timestamp associated
with the layer I am trying to query (specified as a FILTER). I understand
what is happening.. the query by point functionality is querying the
database at the specific POINT and displaying the first row that returns
(the first timestamp). If I delete the first timestamp data, the second
timestep data is displayed and so on. The only thing that changes
between layers is the FILTER.
Does the queryByPoint() function utilize the FILTER definition from the
mapfile? It doesn't seem to be doing so.
(Mapserver 5.0 and PHP/Mapscript)
Here is a sample layer definition:
LAYER
TYPE POINT
CONNECTIONTYPE postgis
NAME 'NAME'
CONNECTION 'host=HOST user=USER dbname=DATABASE'
DATA "the_geom from (SELECT * from forecast left join
grid on grid.gid=forecast.grid_id) as data USING UNIQUE gid USING
SRID=4326"
FILTER "time=TIMESTAMP'2007-11-06 00:00:00'"
METADATA
'DESCRIPTION' '2007-11-06 00:00:00'
'RESULT_FIELDS'
'wind_speed,wind_from_direction,rotation'
'RESULT_HEADERS' 'Wind Speed (m/s), Wind
Direction (from TN), Rotation of Image (from TN)'
'LAYER_ENCODING' 'UTF-8'
END
STATUS OFF
PROJECTION
'init=epsg:4326'
END
TOLERANCE 10
TOLERANCEUNITS pixels
LABELMAXSCALE 60000
TEMPLATE void
CLASS
NAME ">= 0.95 m/s"
EXPRESSION ([wind_speed] >= 0.95)
STYLE
SYMBOL "arrow2"
ANGLE [wind_from_direction]
COLOR 118 0 0
OUTLINECOLOR 0 0 0
SIZE 10
END
TEXT ([wind_speed] m/s - [wind_from_direction] TN)
LABEL
COLOR 118 0 0
OUTLINECOLOR 0 0 0
POSITION AUTO
SIZE small
PARTIALS TRUE
END
END
END
Kyle Wilcox
NOAA Chesapeake Bay Office
410 Severn Avenue
Suite 107A
Annapolis, MD 21403
office: (410) 295-3151
Kyle.Wilcox at noaa.gov
"It is from the wellspring of our despair and the places
that we are broken that we come to repair the world."
- Murray Waas
