queryByAttributes qstring expression and Oracle
    Andreas Albarello
    andreas.albarello at TERRITORIUMONLINE.COM
    Wed Nov  7 02:16:08 PST 2007
Gambin Dejan wrote:
> I have to use queryByAttributes to make an external database jointo
> Oracle database. It works perfectly except when it needs to match an
> expression that includes a slash character („/“), like:
> "[NAME]" =~ /214/2/
> where the string „214/2“ is the value it has to find. If I put "[NAME]"
> =~ /214/, it finds it, but my users will often use „214/2“ in their
> query. I hav tried escaping the slash sign, like:
> "[NAME]" =~ /214\/2/
> but it still doesn't find the value. If I put "[NAME]" =~ /214.2/  then
> the value is found.
Dejan,
there is currently no way to escape a slash inside a regular expression
in MapServer. In addition, I don't think GNU regex supports any kind of
octal or hex notation to specify a certain character like
/214\x2f2/
where \x2f would be the slash character (ASCII #47 = 2f).
Only thing that comes to mind would be to link MapServer against the PHP
PCRE regex, if that still works (haven't tried it in a while).
Perl-compatible regular expressions should then allow you to do the sort
of hex-escape I mentioned above.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web:   www.territoriumonline.com
More information about the MapServer-users
