WFS POST requests: "No template provided" error
Frank Steggink
Frank.Steggink at BENTLEY.COM
Fri Nov 9 08:43:42 EST 2007
Hello Yewondwossen,
Sorry, no improvement here. I'm not getting an error, but I got a time
out, while posting (DescribeFeatureType) to the original server URL
(http://map.ns.ec.gc.ca/MapServer/mapserv.exe?map=/mapserver/services/en
vdat/config.map).
Also, the other service I mentioned,
http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp, uses this same URL as online
resources, which already gave the template error.
I'm a bit out of options right now. As already mentioned, when I'm using
GET, then everything works fine, so our client will be able to access
MapServer. I'll try a few other MapServer WFS's, and see what they do.
(Using POST, and the online resource URL's.) There are quite a lot of
them online. If they all give the same result, then I'm going to file a
bug in Trac. It is no coincidence if several servers, which are set up
independently, all have the same problem.
Frank
-----Original Message-----
From: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
Sent: Thursday, November 08, 2007 17:30
To: Frank Steggink
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WFS POST requests: "No template
provided" error
Hi There,
WFS POST is supported by MapServer. Looking into this thread, you
mentioned a couple of URLS and I have tried the follwing one :
"http://map.ns.ec.gc.ca/MapServer/mapserv.exe?map=/mapserver/services/en
vdat/config.map"
I have tried WFS post requests describefeature and getfeature with
this service and It responds correctly. It is a Mapserve 4.8.3.
I am guessing that there is something 'wrong" with the service
accessed though the script at http://map.ns.ec.gc.ca/envdat/map.aspx
where the post requests are not maybe transfered properly to Mapserver.
Hopefully this helps.
Best Regards,
Frank Steggink wrote:
> Hello Daniel,
> Thanks for the reply. I've tried your suggestion, but unfortunately it
> didn't work. I'm getting the following ServiceException:
> <ServiceExceptionReport
> xmlns="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/ogc
> http://schemas.opengis.net/wms/1.1.1/OGC-exception.xsd">
> <ServiceException>
> msWFSDispatch(): WFS server error. Incomplete WFS request: VERSION
> parameter missing
> </ServiceException>
> </ServiceExceptionReport>
> The URL is http://map.ns.ec.gc.ca/envdat/map.aspx?SERVICE=WFS& and the
> post data is the same as in the original message.
> It really looks like MapServer only accepts GET request for WFS. So,
> the simple fix you suggested will probably not be enough. I'm going to
file a ticket.
> In case
> something needs to be tested, please let me know.
> Frank
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
