Migrating from Windows to Linux: trouble with mapfiles
Steven De Vriendt
gisaalter at GMAIL.COM
Wed Nov 14 10:06:33 EST 2007
Ok, thanks all.
With the help from Kyle"s file I was able to access my mapserver, still I do
get an error
msEvalRegex(): Regular expression error. String
(/etc/mapserver/wmsserver.map?) failed expression test.
I will search the archives whats causing this...
Thanks !
On Nov 14, 2007 4:02 PM, Ed McNierney <ed at topozone.com> wrote:
> Steven -
> In addition to Kyle's example and info, one of the most likely problems is
> that you're moving from an operating system that is not case-sensitive to
> one that is. If your mapfile refers to the file XYZZY and on Windows you
> have a file named xyzzy, that file will be found. On Linux it will not be
> found, as XYZZY and xyzzy are two different filenames.
> - Ed
> Ed McNierney
> TopoZone.com
> ________________________________
> From: UMN MapServer Users List on behalf of Steven De Vriendt
> Sent: Wed 11/14/2007 9:24 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Migrating from Windows to Linux: trouble
> with mapfiles
> Hi list,
> I'm migrating from windows to linux (ubuntu) but I have some trouble
> getting a map-file to work.
> I want to be able to access my server as wms but I'm not sure what to look
> out for when
> making a map-file. I'm having trouble with path-names etc...
> Can someone give me an example of a working mapfile for Linux ?
> That would be great !
> Thanks !
> Steven
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071114/e2abba0b/attachment.html
