Migrating from Windows to Linux: trouble with mapfiles
Gregor Mosheh
gregor at HOSTGIS.COM
Wed Nov 14 11:02:47 EST 2007
Steven De Vriendt wrote:
> Gregor:
> this is my layer-setup for postgis-wms..
> am I missing out something ?
When you request the layer, what is your request? I ask because you have
a wms_title, so I wonder whether you're requesting layer grens or layer
gemeentgrens -- it should be grens.
Other than that, looks great. What is it doing instead of working? When
you hit mapserv directly via a manual WMS request, does it generate a
blank image, or an error? Do you have a WMS URL pointing at this layer,
which we could use to check?
I might also recommend that you go over the WMS Server HOWTO on the
website, just in case something got overlooked. Check the usual stuff:
projections, wms_srs listing, read your WMS server's capabilities
document and make sure it's sane, ...
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
