Migrating from Windows to Linux: trouble with mapfiles
Fawcett, David
David.Fawcett at STATE.MN.US
Wed Nov 14 11:06:56 EST 2007
If you use this same connection info and data, can you get it to display
as a line layer using mode=map?
If not, I would debug this as a normal layer first and then convert it
to a WMS layer.
David.
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Steven De Vriendt
Sent: Wednesday, November 14, 2007 9:55 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Migrating from Windows to
Gregor:
this is my layer-setup for postgis-wms..
am I missing out something ?
LAYER
NAME "grens"
METADATA
"wms_title" "gemeentegrens"
END
CONNECTIONTYPE postgis
CONNECTION "host=****** <http://80.201.239.208/> port=****
dbname=***** user=****** password=*****"
DATA "the_geom from alrgemline"
TYPE LINE
CLASS
NAME "KadScan"
COLOR 221 221 221
OUTLINECOLOR 238 238 238
END
PROJECTION
"init=epsg:31300"
END
On Nov 14, 2007 4:06 PM, Steven De Vriendt <gisaalter at gmail.com
> wrote:
Ok, thanks all.
With the help from Kyle"s file I was able to access my
mapserver, still I do get an error
msEvalRegex(): Regular expression error. String
(/etc/mapserver/wmsserver.map?) failed expression test.
I will search the archives whats causing this...
Thanks !
On Nov 14, 2007 4:02 PM, Ed McNierney < ed at topozone.com>
wrote:
Steven -
In addition to Kyle's example and info, one of
the most likely problems is that you're moving from an operating system
that is not case-sensitive to one that is. If your mapfile refers to
the file XYZZY and on Windows you have a file named xyzzy, that file
will be found. On Linux it will not be found, as XYZZY and xyzzy are
two different filenames.
- Ed
Ed McNierney
TopoZone.com
Steven De Vriendt
Sent: Wed 11/14/2007 9:24 AM
Subject: [UMN_MAPSERVER-USERS] Migrating from
Hi list,
I'm migrating from windows to linux (ubuntu) but
I have some trouble getting a map-file to work.
I want to be able to access my server as wms but
I'm not sure what to look out for when
making a map-file. I'm having trouble with
path-names etc...
Can someone give me an example of a working
mapfile for Linux ?
That would be great !
Thanks !
Steven
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071114/ca255edf/attachment.html
