Migrating from Windows to Linux: trouble with mapfiles
Milo van der Linden
mlinden at ZEELANDNET.NL
Wed Nov 14 11:20:55 EST 2007
It seems that this might be a rights issue. Is the postGIS database
running on the same machine as qGIS? is the webserver on the same
machine as the database? Did you allow access to the postGIS database in
the pg_hba.conf? or is it set to localhost access only?
Kind regards,
Milo van der Linden
Steven De Vriendt schreef:
> Gregor,
> I'm trying to access my wms in qgis. When I access this url in qgis:
> http://80.201.239.208:8888/cgi-bin/mapserv?map=/etc/mapserver/wmsserver.map&version=1.1.0&service=wms&request=getcapabilities
> <http://80.201.239.208:8888/cgi-bin/mapserv?map=/etc/mapserver/wmsserver.map&version=1.1.0&service=wms&request=getcapabilities>
> I'm getting an error that qgis can't access the postgis db.
> However, when I try to connect to postgis-db in qgis using same
> connection params I can access it just fine...strange..
> Steven
> On Nov 14, 2007 5:02 PM, Gregor Mosheh <gregor at hostgis.com
> <mailto:gregor at hostgis.com>> wrote:
> Steven De Vriendt wrote:
> > Gregor:
> > this is my layer-setup for postgis-wms..
> > am I missing out something ?
> When you request the layer, what is your request? I ask because
> you have
> a wms_title, so I wonder whether you're requesting layer grens or
> layer
> gemeentgrens -- it should be grens.
> Other than that, looks great. What is it doing instead of working?
> When
> you hit mapserv directly via a manual WMS request, does it generate a
> blank image, or an error? Do you have a WMS URL pointing at this
> layer,
> which we could use to check?
> I might also recommend that you go over the WMS Server HOWTO on the
> website, just in case something got overlooked. Check the usual
> stuff:
> projections, wms_srs listing, read your WMS server's capabilities
> document and make sure it's sane, ...
> Gregor Mosheh / Greg Allensworth
> System Administrator, HostGIS cartographic development & hosting
> services
> http://www.HostGIS.com/
> "Remember that no one cares if you can back up,
> only if you can restore." - AMANDA
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071114/9e64178c/attachment.html
