Migrating from Windows to Linux: trouble with mapfiles
Steven De Vriendt
gisaalter at GMAIL.COM
Wed Nov 14 11:39:50 EST 2007
Gregor,
Thanks :-) . I will have a look at the extent and projections like you
suggest.
I will first have a look at my security...I see QGIS is quite friendly in
showing information
where it shouldn't and not showing information where it should :-)
Thanks again
Steven
On Nov 14, 2007 5:36 PM, Gregor Mosheh <gregor at hostgis.com> wrote:
> Steven De Vriendt wrote:
> > Solved the error too, it was a DMZ-IP-issue.
> Hey, I was right. :)
> > Now, I'm able to acces my WMS, can add the layer "grens", but it's not
> > showing up in qgis.
> The most likely culprit is the extent and the projections. That seems to
> be the #1 cause of "nothing shows up" phenomena. But yeah, you're past
> the biggest hurdles; just ask if you need anything else.
> Gregor Mosheh / Greg Allensworth
> System Administrator, HostGIS cartographic development & hosting services
> http://www.HostGIS.com/
> "Remember that no one cares if you can back up,
> only if you can restore." - AMANDA
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071114/b2306b8e/attachment.html
