Ruby/MapScript quark in version 5.0.0
Brant Anderson
rabrant at GMAIL.COM
Sun Nov 18 04:16:46 EST 2007
Heres some code I wrote in Ruby on Rails for a dynamic map:
def dynamic_map
# Grab values from the form
@minx_d = params[:minx_d].to_f # default extent values
@miny_d = params[:miny_d].to_f
@maxx_d = params[:maxx_d].to_f
@maxy_d = params[:maxy_d].to_f
@minx_img = params[:minx_img].to_f # image coordinate values
@miny_img = params[:miny_img].to_f
@maxx_img = params[:maxx_img].to_f
@maxy_img = params[:maxy_img].to_f
@pin = params[:pin].to_s # parcel identification number
@minx = params[:minx].to_f # current extent values
@miny = params[:miny].to_f
@maxx = params[:maxx].to_f
@maxy = params[:maxy].to_f
@zoomfactor = params[:zoomfactor].to_i # -2 is zoomout, -1 or 1 is
recenter, 2 is zoomin (Integer value).
@tool = params[:tool].to_s # This should match the 'getToolbox()'
JavaScript function.
# Initialize MapObj
@map = MapObj.new session['mapfile']
@map.setExtent @minx, @miny, @maxx, @maxy
# Paint the selection yellow.
layer = @map.getLayerByName 'parcel_poly'
layer.classitem = 'PIN'
class_poly_hilite = layer.getClass 0
layer.insertClass class_poly_hilite
class_poly_hilite.name = 'poly_hilite'
class_poly_hilite.setExpression @pin.strip
class_poly_hilite_style = class_poly_hilite.getStyle 0
class_poly_hilite_style.color.setRGB 250, 250, 125
# Add a push-pin.
layer_pt = @map.getLayerByName 'parcel_point'
layer_pt.classitem = 'pin'
class_pt_hilite = layer_pt.getClass 0
layer_pt.insertClass class_pt_hilite
class_pt_hilite.name = 'pt_hilite'
class_pt_hilite.setExpression @pin.strip
class_pt_hilite_style = class_pt_hilite.getStyle 0
class_pt_hilite_style.size = 32
class_pt_hilite_style.setSymbolByName @map, 'pushpin'
# Apply the zoom (aka change the extent value).
if @minx_img != @maxx_img && @miny_img != @maxy_img
apply_box @map, @minx_img, @miny_img, @maxx_img, @maxy_img
elsif @tool == 'fullview'
@map.setExtent @minx_d, @miny_d, @maxx_d, @maxy_d
else
apply_zoom @map, @zoomfactor, @minx_img, @miny_img
end
# Set the new extent values to be sent back to the form.
@minx = @map.extent.minx.to_f
@miny = @map.extent.miny.to_f
@maxx = @map.extent.maxx.to_f
@maxy = @map.extent.maxy.to_f
render :partial => 'map_image'
end
Here's a snippet from my mapfile:
LAYER #-- Parcels Polygon Layer
NAME parcel_poly
DATA parcelpydoug04
MAXSCALE 72000
STATUS DEFAULT
TYPE POLYGON
TRANSPARENCY 50
CLASS
NAME "Parcels"
COLOR -1 -1 -1
OVERLAYOUTLINECOLOR 250 0 0
OVERLAYSYMBOL 'circle'
OVERLAYSIZE 2
END
END #-- Parcels Polygon Layer
LAYER #-- Parcels Point Layer
NAME parcel_point
CONNECTIONTYPE postgis
CONNECTION "user=<username_goes_here> dbname=experiments host=localhost
port=5432 password=<password_goes_here>"
DATA "wkb_geometry from mn_douglas_parcelpoints"
MAXSCALE 72000
STATUS DEFAULT
TYPE POINT
#-- TOLERANCEUNITS miles
#-- TOLERANCE 10
TRANSPARENCY 50
CLASS
NAME "Parcel Point"
COLOR 0 250 0
SYMBOL 'circle'
SIZE 10
END
END #-- Parcels Point Layer
In version 4, the parcel lines and points are drawn. The code written above
highlights the selected parcel and changes the point graphic to a push-pin.
In version 5, the parcel lines and points are not drawn. Only the
highlighted parcel is drawn. Why? How do I write my code so that it displays
the defaults from the mapfile as well as the newly defined class? I'm
stumped.
Any comments or suggestions appreciated.
~Brant
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071118/304b6fd3/attachment.html
