Subject: Re: Mapserv not accepting POST method
Ben Madin
ben at REMOTEINFORMATION.COM.AU
Sun Nov 18 15:41:17 EST 2007
G'day Jeff,
Excuse me if this is already checked!
On 18/11/2007, at 3:01 PM, MAPSERVER-USERS automatic digest system
wrote:
> Could the mapserv version I am using be what is causing this
> problem? Is
> there a command I can run on the command line or through my web
> service to
> get the version info and re-form a reply? I am running OS X
> 10.4.10, and the
> apache in my previous post. Thanks again, and please advise when
> you can.
You could try ./mapserv -v :
freebsd:/Library/WebServer/CGI-Executables $ ./mapserv -v
MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
additionally, If you go to :
http://localhost/cgi-bin/mapserv
do you see :
No query information to decode. QUERY_STRING is set, but empty.
cheers
Ben
Ben Madin
REMOTE INFORMATION
Broome WA 6725
ben at remoteinformation.com.au
Out here, it pays to know...
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071119/969f0262/attachment.html
