Displays the same error. What's happen?, I don't understand. This code is very simple and this is a typical example of Java Mapscript. When I have tried compile the examples with "make test", I have had this error: *** glibc detected *** java: malloc(): memory corruption: 0x45e68d78 *** Thanks for your time. Luis Conti.
