Problems with Java Mapscript
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Nov 19 09:32:49 EST 2007
You are using a quite old (and unsupported) version of mapserver.
You should first upgrade to version 5.
Umberto
On Nov 19, 2007 1:03 PM, Luis Conti <conti_lui at gva.es> wrote:
> Displays the same error.
> What's happen?, I don't understand. This code is very simple and this is a
> typical example of Java Mapscript.
> When I have tried compile the examples with "make test", I have had this error:
> *** glibc detected *** java: malloc(): memory corruption: 0x45e68d78 ***
> Thanks for your time.
> Luis Conti.
