Can MapServer center wrapped labels?
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Nov 20 00:52:52 EST 2007
Hi John: The GD rendering software doesn't support text alignment although it's something
being discussed for 5.2. One possible work around would be to use a different class expression
to detect long labels and draw them differently. There's a length operator in the logical expression
support so you can have different classes based on the length of a string. If you're using PostGIS
perhaps there is the possibility of a custom function that would place a wrap character in the right
spot based on length? Just an idea.
Sorry...
Steve
>>> John Maurer <maurerj at NSIDC.ORG> 11/19/07 3:24 PM >>>
Hi everybody,
When using the WRAP keyword for labels, is there a way to also center
them? I'm getting things like:
Greenland
Ice
Sheet
This would look a heck of a lot better on my maps centered as:
Greenland
Ice
Sheet
Or even better, if I could specify a max line length for the WRAP
keyword and end up with:
Greenland
Ice Sheet
Are either of these things possible? Couldn't find anything in the
documentation so I'm guessing not??
Thanks!,
John Maurer
John Maurer
Web/Database Applications Engineer
National Snow and Ice Data Center (NSIDC)
University of Colorado at Boulder
http://cires.colorado.edu/~maurerj
+1-303-735-5316
"Without geography, you're nowhere!"
