ms4w dlls for IIS-installation
Milo van der Linden
mlinden at ZEELANDNET.NL
Fri Nov 23 07:54:30 EST 2007
Hello Sven!
Here is my configuration on Windows 2003 Server IIS 6.0
1. Download the MS4W PHP5 Base Installer v2.2.6 (Sept 18, 2007)
2. Open the zip ms4w_2.2.6.zip and copy the content of
/ms4w/Apache/cgi-bin gekopieerd naar to the (virtual) folder that will
serve as your cgi-bin
3. Copy /ms4w/gdaldata, /ms4w/gdalplugins, /ms4w/proj and ms4w/tools
somewhere on your system, not necessary a path that can be reached from
the webserver (IIS) I created a folder C:\mapserver that contains
everything that is mapserver related
Set up the system variables:
Add to PATH:
c:\MapServer\\cgi-bin; C:\MapServer\tools\gdal-ogr;
C:\MapServer\\tools\mapserv; C:\MapServer\tools\shapelib;
C:\MapServer\proj\bin; C:\MapServer\tools\shp2tile;
C:\MapServer\tools\shpdiff; C:\MapServer\tools\avce00;
And create:
GDAL_DATA=C:\MapServer\gdaldata
GDAL_DRIVER_PATH=C:\MapServer\gdalplugins
PROJ_LIB=C:\MapServer\proj\nad
Assign rights to IIS to read from your directories to IS_WPG (Workgroep
IIS) on folder c:\mapserver and all sub-dirs:
Read and Execute
List Folder Content
Read
Create a webservice extension that points to
C:\MapServer\cgi-bin\mapserv.exe set it to "Allow"
restart IIS by starting and stopping the Webserver service, otherwise
the system variables will not be updated.
Good luck!
Sven Schroeter schreef:
> Hallo,
> I want to install the latest Mapserver 4.10 on a Windows 2003 Server
> with IIS (PHP 5.2.3 is already installed as cgi).
> In older mapserver-versions I copied some .dlls in the system32 and
> the mapserv.exe in the cgi-bin of the IIS. Then php-mapscript in the
> ext-folder of php and everything worked fine.
> With the install-packages ms4w (f.e. ms4w_2.2.5) there are many dlls
> in the cgi-bin (ms4w\Apache\cgi-bin) and I dont know what .dll are
> really used and important for mapserver and mapscript.
> Some files are for apache or php5 (f.e. php5apache2.dll) .
> Can anybody list the basic .dlls I need for a installation with IIS?
> Thanks
> Sven
Milo van der Linden
skype: milovanderlinden <skype:milovanderlinden?add>
mlinden at zeelandnet.nl <mailto:mlinden at zeelandnet.nl>
milovanderlinden at gmail.com <mailto:milovanderlinden at gmail.com>
milo at 3dsite.nl <mailto:milo at 3dsite.nl>
http://www.3dsite.nl
De informatie in dit bericht reflecteert mijn persoonlijke mening en
niet die van een bedrijf of instantie. Aan de informatie kunnen geen
rechten worden ontleend. Indien dit bericht onderdeel is van een forum,
mailing-list of community dan gelden automatisch de bij het betreffende
medium behorende voorwaarden. The information in this message reflects
my personal opinion and not that of a company or public body. All rights
reserved.If this message is contained in a mailing-list or community,
the rights on the medium are automatically adapted.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071123/cc2b7a1d/attachment.html
