UPDATE Re: C# Mapscript ASP.NET Deployment Problem
Tamas Szekeres
szekerest at GMAIL.COM
Sat Nov 24 18:40:28 EST 2007
I should also ask you about the mapserver version, which dependencies
are compiled in, and the actual use case of your application that
produce the problem with special regards of the usage of the mapscript
objects.
Best regards,
Tamas
2007/11/24, Bruno Gendron <bruno_gendron at yahoo.com>:
> Update to my previous post...
> When run in VS 2005 using VS internal Development Server, everything's fine...
> However, it crashes when using IIS Web Server, even from within VS debugging
> environment...
> Hope this will help someone understand what's going wrong!
> Bruno
