antialiased lines with AGG
rich.fromm
nospam420 at YAHOO.COM
Tue Nov 27 17:03:31 EST 2007
Summary: I was previously trying to get antialiased lines working with
cartographic symbols and having no luck. I've now switched my rendering
backend from GD to AGG and am still not able to get antialiased lines
working.
I have downloaded and installed AGG 2.5. I realize that for licensing
reasons, mapserver is currently suggesting AGG 2.4. Might this be
significant? I haven't yet tried this with AGG 2.4, I had thought the issue
was just one of licensing, and not functionality. In case it's at all
relevant, some details of my install and build experience can be found here:
http://lists.umn.edu/cgi-bin/wa?A2=ind0711&L=mapserver-users&D=1&T=0&O=D&X=5A77662D019C30E09D&Y=nospam420%40yahoo.com&P=52157
http://www.nabble.com/AGG-install-tf4390828.html#a13979959
As suggested by Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>:
http://lists.umn.edu/cgi-bin/wa?A2=ind0711&L=mapserver-users&D=1&T=0&O=D&X=5A77662D019C30E09D&Y=nospam420%40yahoo.com&P=51780
http://www.nabble.com/AGG-docs-%28and-5.0.0-docs-in-general%29---tf4879380.html
I am using the following as my reference for AGG:
http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics/?searchterm=agg
There it says:
All rendering is now done antialiased by default. All ANTIALIAS keywords are
now ignored
I have narrowed things down to a fairly small testcase, with just a single
line layer:
LAYER
NAME majhwys
DATA MajHwys
STATUS DEFAULT # DEFAULT means on
TYPE LINE
CLASS
NAME "Major Highways"
STYLE
COLOR 32 32 32
END
END
END
I have alternatively tried all three of the suggested PNG OUTPUTFORMAT's
from
that web page (only one at a time, of course):
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGBA
END
OUTPUTFORMAT
NAME 'AGG_Q'
DRIVER AGG/PNG
IMAGEMODE RGB
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
And I have also tried the following suggested OUTPUTFORMAT from
http://mapserver.gis.umn.edu/development/rfc/ms-rfc-32/?searchterm=AGG
OUTPUTFORMAT
NAME 'AGG_PNG24'
DRIVER AGG/PNG
IMAGEMODE RGB
END
I have not tried JPEG, as I have not compiled with jpeg support.
Additionally, I have alternatively tried this:
IMAGETYPE PNG
vs. this:
IMAGETYPE PNG24
So 8 permutations total. In none of the cases am I rendering antialiased
lines.
I tried adding 'ANTIALIAS TRUE' to the STYLE section (contrary to the advice
in the docs), and indeed it does not help.
Antialiased text (in a more complex example) is working for me. And indeed
I
no longer need the 'ANTIALIAS TRUE' in the corresponding LABEL section like
I
used to with GD. The text is indeed antialiased automatically without it
now,
like the docs claim.
But I can't get antialiased lines. This is true if I specify no width (and
get lines of width 1), or if I specify a width with the WIDTH parameter in
the
STYLE section.
See the attached png image which was generated using the first IMAGETYPE and
first OUTPUTFORMAT shown above, and has all of the major highways in all of
CA
and NV drawn with a single pixel width. [I hope this worked, the nabble web
interface to this mailing list isn't all that clear on whether or not it
did...]
This is with mapserver-5.0.0, running on debian sarge (3.1), served via CGI
with apache2 2.0.54-5sarge1.
Thanks for any help that anyone might be able to provide.
- Rich Fromm
View this message in context: http://www.nabble.com/antialiased-lines-with-AGG-tf4884770.html#a13980962
Sent from the Mapserver - User mailing list archive at Nabble.com.
