antialiased lines with AGG
rich.fromm
nospam420 at YAHOO.COM
Tue Nov 27 17:38:36 EST 2007
tbonfort wrote:
> it's your IMAGETYPE that you're setting wrong. it should reference
> one of the agg outputformats, eg IMAGETYPE AGG or IMAGETYPE AGG_Q
Thank you so much! That did the trick.
Image size is somewhat important to me, so I suspect I'll be using IMAGETYPE
AGG_Q. Other than what's shown in the example at:
http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics/view
do you know if there are any other FORMATOPTION's within the OUTPUTFORMAT
that can be tweaked?
The OUTPUTFORMAT docs within the mapfile reference still just make reference
to GD options, not AGG:
http://mapserver.gis.umn.edu/docs/reference/mapfile/outputformat
I suppose if all else fails I could look in the source, although I'm not
sure if that would be more appropriate in the mapserver source or the agg
source.
View this message in context: http://www.nabble.com/antialiased-lines-with-AGG-tf4884770.html#a13981498
Sent from the Mapserver - User mailing list archive at Nabble.com.
