antialiased lines with AGG
thomas bonfort
thomas.bonfort at GMAIL.COM
Tue Nov 27 17:44:59 EST 2007
I think they are all in that howto, except for the fact that you can
specify your own palette if using quantization. what are you looking
for in particular?
On Nov 27, 2007 11:38 PM, rich.fromm <nospam420 at yahoo.com> wrote:
> tbonfort wrote:
> > it's your IMAGETYPE that you're setting wrong. it should reference
> > one of the agg outputformats, eg IMAGETYPE AGG or IMAGETYPE AGG_Q
> Thank you so much! That did the trick.
> Image size is somewhat important to me, so I suspect I'll be using IMAGETYPE
> AGG_Q. Other than what's shown in the example at:
> http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics/view
> do you know if there are any other FORMATOPTION's within the OUTPUTFORMAT
> that can be tweaked?
> The OUTPUTFORMAT docs within the mapfile reference still just make reference
> to GD options, not AGG:
> http://mapserver.gis.umn.edu/docs/reference/mapfile/outputformat
> I suppose if all else fails I could look in the source, although I'm not
> sure if that would be more appropriate in the mapserver source or the agg
> source.
> View this message in context: http://www.nabble.com/antialiased-lines-with-AGG-tf4884770.html#a13981498
> Sent from the Mapserver - User mailing list archive at Nabble.com.
