postgis table joins in layer DATA and FILTER
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Nov 30 17:06:50 EST 2007
Hi David,
Try this:
DATA "the_geom from (select the_geom, name, checked, gid from sm100k a,
files b where a.uid=b.uid ) as foo using SRID=4326 using unique gid"
You have to put your joins into a sub-select.
Regards,
-Steve W
David Niergarth wrote:
> I'm wondering if there is a way to join two postgres tables within a
> layer object.
> We have a postgres table with a postgis geometry column and other
> details (name, address columns). Problem is, we need to join that table
> with a couple of other tables in the same database.
> We have tried getting around the join problem by creating a view that
> hides the needed joins but performance is terrible. We have also tried
> using an exists subselect but performance is even worse. Creating a
> custom table for each map we want to generate is completely impractical
> due to the size of the database.
> However, writing sql as joins is super quick.
> Here's an example of what we'd like to accomplish.
> DATA "p.the_geom from people_points p, spam_table s, eggs_table e"
> FILTER "p.id=s.id and p.id=e.id and s.spam='foo' and e.eggs='bar'"
> Is there some other way to do this without having to create a (massive
> and unnormalized) table with all the info we need or a view?
> We're using postgres 8.1, mapserver 4.9, ubuntu server 7.04. We've heard
> there were improvements to postgres (maybe in 8.2) that improved view
> performance, but it's not practical for us to upgrade right now.
> Any info or suggestions welcome,
> --David Niergarth
