4D Raster access NOT via WMS?
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri Oct 12 09:30:59 EDT 2007
Samuel Hiatt wrote:
> Hi! Thanks for the reply.
> So I suppose when I make a WMS request with TIME Mapserver applies the
> filter behind the scenes, finding which feature in my tile_index.shp
> represents the correct time and then processes the raster pointed to by
> that feature? So if I want to implement the same kind of thing with
> mapscript I'd have to write the filter myself?
That is correct : assuming that the underlying data can be filtered
using a time field, you need to know the attribute and build the time
expression and set it using mapscript.
> The reason I am interested in doing this is to extend temporal
> functionality to ka-map. I may end up abandoning that approach and
> moving to a javascript WMS client (like OpenLayers of MapBuilder) instead.
> Thanks for your help.
> Sam
> On 10/11/07, *Yewondwossen Assefa* <assefa at dmsolutions.ca
> <mailto:assefa at dmsolutions.ca>> wrote:
> Hi there,
> The Time parameter that is sent with a WMS request is simply
> converted
> to a time expression and set on the filter object of the layer. In the
> case of wms. the metadata wms_timeitem will be used for the
> attribute name.
> if you are using mapscript, you would need to build the time
> expression manually and set the filter parameter. Please refer to
> http://mapserver.gis.umn.edu/docs/howto/wms_time_support (section 2.5)
> to see how time parameters are interpreted.
> Best Regards,
> Samuel Hiatt wrote:
> > I am excited to see that Mapserver supports 4D raster layers for WMS,
> > but I am curious if this functionality can be extended to mapscript
> > calls as well? For example, if I set up a raster layer with a TIME
> > dimension then will it be possible for me to request an image for a
> > specific time with mapscript? Or would I have to do this with a
> WMS call?
> > Thanks!
> > Sam
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca <mailto:assefa at dmsolutions.ca>
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
