[mapserver-users] change AGG Driver via mapscript
schroeter at netgis.de
Thu Apr 17 07:37:59 EDT 2008
I solved my problem:
I set a second outputformat in my mapfile:
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
TRANSPARENT ON
END
and change it via mapscript with
$map->selectOutputFormat("image/png");
greetings
Sven
----- Original Message -----
To: <mapserver-users at lists.osgeo.org>
Sent: Tuesday, April 15, 2008 2:17 PM
Subject: [mapserver-users] change AGG Driver via mapscript
> Hallo,
> the standard-output-format in my mapfile is AGG_JPEG:
> OUTPUTFORMAT
> NAME "AGG_JPEG"
> DRIVER AGG/JPEG
> IMAGEMODE RGBA
> FORMATOPTION "QUALITY=88"
> END
> I try to change the outputformat via mapscript to get a transparent
> 256-color-png:
> $map->outputformat->set("name", "png");
> $map->outputformat->set('driver','GD/PNG');
> $map->outputformat->set('transparent',MS_ON);
> this works fine, but I get a transparent 24 bit png
> if I try to set the imagemode:
> $map->outputformat->set("imagemode", MS_IMAGEMODE_PC256);
> I get no picture but this warning:
> PHP Warning: [MapServer Error]: msImageCreateAGG(): AGG driver only
> supports RGB or RGBA pixel models
> how can I disable AGG?
> thanks Sven
