[mapserver-users] grayscale shaded relief in mapserver
Fawcett, David
David.Fawcett at state.mn.us
Mon Apr 21 12:28:24 EDT 2008
Have you ruled out a problem with projection or extent?
I was hoping to see the top of the map file too, to see what the output projection, extent, and units lines looked like.
Also, are you calling the layer name explicitly in the cgi request? If not, try setting the layer status to DEFAULT for testing purposes.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Guillaume Sueur
Sent: Monday, April 21, 2008 11:17 AM
To: Fawcett, David; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] grayscale shaded relief in mapserver
the TIF goes with a .TAB and its georeferencing informations. It looks
ok with Qgis.
The mapfile is straight-forward :
LAYER
DATA "uploaded/AUbwV8_32.TIF"
NAME "shaded"
PROCESSING "COLOR_MATCH_THRESHOLD=3"
PROJECTION
"init=epsg:27563"
END
STATUS ON
TYPE RASTER
UNITS METERS
END
Thanks for your interest,
Guillaume
Fawcett, David a écrit :
> Have you stripped out all of the projection, etc. and just tried to
> output the image?
> What does your map file look like?
> David.
> Guillaume Sueur
> Sent: Monday, April 21, 2008 3:48 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] grayscale shaded relief in mapserver
> Hi list,
> I've got a grayscale TIF showing shaded relief which I can't manage to
> display properly with mapserver. The image is just white. gdalinfo gives
> : Band 1 Block=4367x1 Type=Byte, ColorInterp=Gray I assume the georef is
> ok. I tried few things like resampling it to 32 colors, or "PROCESSING
> "COLOR_MATCH_THRESHOLD=3" as I've found in mails archives, but without
> any luck.
> Any clue ?
> Thanks
mapserver-users mailing list
mapserver-users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/mapserver-users
