[MAPSERVER-USERS] Key labelcache_map_edge_buffer does not exist
(While using TiF files in Raster Layer)
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed Aug 27 09:44:10 EDT 2008
This should only happen if you have you have debug ON at the map level.
Setting it to OFF should get rid of the message.
Best Regards,
Ritesh Ambastha wrote:
> Hello,
> I am using Tilecache to generate tiles by reading few raster layers from my
> mapfile. I have successfully generated tiles using tilecache and mapserver
> vector layers. My raster images includes TIF files.
> When I checked my logs, I got these errors/warning:
> <snip>
> getMetaData: Hash table error. Key labelcache_map_edge_buffer does not exist
> msDrawLabelCacheGD(): labelcache_map_edge_buffer = -15
> </snip>
> I have not used labelcache_map_edge_buffer anywhere in the mapfile. I tried
> to keep a negative value to this in the METADATA seciton, but it didn't
> worked.
> I am using MapServer version 5.0.0.
> Any help will be highly appreciated.
> Thanks,
> Ritesh Ambastha
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
