[mapserver-users] Parameters in memory
Jacolin Yves
yjacolin at free.fr
Fri Aug 29 04:42:06 EDT 2008
Hi list,
I have a strange issue using mapserv. I think this will be difficult to
reproduced, but I try asking in the list ;)
I am using mapserver as WMS service with Openlayers and tilecache. We are
moving our application to the release 2 and so we are cleaning the spatial
configuration. For example, we changed the SHAPEPATH parameter
from /var/local/cartoweb/transparens_immo/cres to /var/local/spatial/.
This is a very good example because my problem come from this changing. So we
moved spatial data in this new directory and changed SHAPEPATH in the
mapfile. This change works for almost all layers. I don't know why, some
layers don't want to use the new SHAPEPATH and I get this kind of error when
requesting WMS layer (here named ortho_92):
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport
SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named
'ortho_92'.
msDrawRaster(): Unable to access file.
(/var/local/cartoweb/transparens_immo/cres/Referentiel/Bd_Ortho/92/92-2003-0595-2415-LA2E-C07.ecw)
</ServiceException>
</ServiceExceptionReport>
Is this something known? I am using mapserver 4.10.1 on Debian Etch. Mapserver
come from C2C repository. thanks for your help.
Regards,
Y.
Yves Jacolin
http://softlibre.gloobe.org
