[mapserver-users] Postgis query
Paul Ramsey
pramsey at cleverelephant.ca
Tue Dec 2 08:12:20 EST 2008
If you turn on statement logging in pgsql, you can see what SQL
mapserver is sending to pgsql. That will clarify if there is a way for
you to change your statement to get what you want, or if there's an
error in what mapserver is asking for, or an error in how mapserver is
processing what is returned to it.
P
On Tue, Dec 2, 2008 at 2:37 AM, mark balman <mark.balman at gmail.com> wrote:
> Hi All
> I am trying to output a query from postgis using three tables and it
> is not quite working.
> First table is a quarter degree grid (spatial table)
> Second table is a table with each grid cell id along with many species
> id per grid cell
> Third table is list of species
> My query definition works well as the following (using two tables only)
> select fid_1, the_geom AS the_geom, spcgrid.id as gid, spcid
> from spcdensity
> left join spcgrid on spcdensity.fid_1 = spcgrid.fid
> This produces exactly what I want through mapserver, query a grid cell
> and it returns a list of species within that grid cell
> My problem is that I want to return a list of species names so my
> query at present is defined as:
> select spcid, spccommonname, fid_1, spcdensity.the_geom, spcid as gid
> from spcgrid left join species on spcgrid.spcid = species.spcrecid
> inner join spcdensity on spcdensity.fid_1 = spcgrid.fid
> Although the query works when run in pgadmin, when I query a grid cell
> I get a list of one species repeated. I am slightly confused as to
> what I am missing here, can anyone provide me with some pointers?
> Thanks in advance
> Mark
> mapserver-users at lists.osgeo.org
