[mapserver-users] ogr2ogr hangs converting e00 files
Arthur A. Person
person at meteo.psu.edu
Tue Dec 23 14:33:46 EST 2008
Jeff,
On Tue, 23 Dec 2008, Jeff McKenna wrote:
> Arthur A. Person wrote:
>> Hi...
>> I'm trying to convert .e00 international boundary files into shapefile
>> format using ogr2ogr, but when I run the conversion, ogr2ogr just hangs and
>> hogs the processor. Here's the details:
>> OS: RH Linux 4.7 (2.6.9-78.0.8.ELsmp)
>> gdal: 1.5.1 basic
>> command: ogr2ogr -f "ESRI Shapefile" bound.shp bound.e00
>> output:
>> ERROR 6: Can't create fields of type IntegerList on shapefile layers.
>> (then hangs hogging the processor...)
>> Even though ogr2ogr hangs, it still produces a bunch of files including a
>> bound.shp file. However, when I try to display that file using mapserver,
>> it just produces a blank screen.
>> output from ogrinfo for bound.e00:
>> Had to open data source read-only.
>> INFO: Open of `bound.e00'
>> using driver `AVCBin' successful.
>> 1: ARC (Line String)
>> 2: CNT (Point)
>> 3: LAB (Point)
>> 4: PAL (Polygon)
>> The bound.e00 file I'm using for testing is the North American Atlas
>> political boundaries file from nationalatlas.gov.
>> On a related note, does anyone know whether an open source file of
>> international political/land boundaries exists that would save me the work
>> of trying to combine a bunch of individual files together? I've searched
>> high and low and can't seem to find anything...
>> Thanks...
>> Art
> I don't believe e00 write access is supported by OGR
> (http://www.gdal.org/ogr/drv_avce00.html), so I would use the AVCE00 library
> (http://avce00.maptools.org/avce00/index.html) to convert to coverage and
> then ogr2ogr to shapefile.
Okay... I did an avcimport of the bounds.e00 file and got a bunch of new
files. Then I did the ogr2ogr on that, and it ran and finished. And, it
pops up in mapserver like it's supposed to. A bit mysterious to me, but
your suggestion worked. Thanks for the help...
Art
> happy holidays all.
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org
Arthur A. Person
Research Assistant, System Administrator
Penn State Department of Meteorology
email: person at meteo.psu.edu, phone: 814-863-1563
