[mapserver-users] LABEL - POSITION and FONT Calculations
Donald Kerr
donald.kerr at dkerr.co.uk
Mon Dec 29 09:13:39 EST 2008
I have a problem that has me stumped.
I am trying to place text on a map as a LABEL which I can successfully do
with the following code:
LAYER CONNECTIONTYPE postgis
NAME "CartographicText"
CONNECTION "user=postgres dbname=MasterMap host=localhost"
DATA "geom FROM (SELECT toid, featurecode, textstring,
orientation/10 AS orientation, fontnumber, anchorposition, textstyle, geom
FROM cartographictext) AS foo USING UNIQUE toid"
METADATA
"IMAGEFORMAT" "AGGA"
END
STATUS DEFAULT
MINSCALEDENOM 1
MAXSCALEDENOM 1300
SYMBOLSCALEDENOM 1250
TYPE ANNOTATION
LABELITEM textstring
CLASS
# Road Name Or Classification
EXPRESSION ([featurecode] = 10169)
LABEL
TYPE truetype
FONT arial
SIZE 10
MAXSIZE 30
MINSIZE 0
COLOR 0 0 0
ANTIALIAS TRUE
ANGLE [orientation]
END # LABEL
END # CLASS
CLASS
# Building or Structure Text
EXPRESSION ([featurecode] = 10026)
LABEL
TYPE truetype
FONT arial
SIZE 7
MAXSIZE 21
MINSIZE 0
COLOR 0 0 0
ANTIALIAS TRUE
ANGLE [orientation]
END # LABEL
END # CLASS
END # LAYER
I want to add POSITION based on [anchorposition] from the database.
The database grid for anchorposition is as follows:
2 5 8
1 4 7
0 3 6
Whereas MapServer is as follows
ul uc ur
cl cc cr
ll lc lr
Which is probably:
0 1 2
3 4 5
6 7 8
The question is: Is it possible to take the values from the database and
convert them for use within the LABEL e.g. 2 = ul = "POSITION ul" or 5 = uc
= "POSITION uc"?
I would also like to be able to change the Font based on [fontnumber] from
the database e.g. 0 = Arial = "FONT arial" or 1 = Times = "FONT times"
Are these things possible?
Many thanks.
Regards,
Donald Kerr
