[mapserver-users] RE: [UMN_MAPSERVER-USERS] Strange Projection
Issue in MapServer
Fawcett, David
David.Fawcett at state.mn.us
Fri Feb 15 15:18:22 EST 2008
Robert,
Please reply to the list too, there are a lot of people on the list who
know a lot more about this than I do.
It would be useful to see a more verbose output on both of the commands,
not necessarily for each feature in the tileindex, but at least the
extent, etc.
David.
-----Original Message-----
Sent: Friday, February 15, 2008 11:02 AM
To: Fawcett, David
Subject: Re: [UMN_MAPSERVER-USERS] Strange Projection Issue in
$ gdalinfo img.tif | grep EPSG
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
AUTHORITY["EPSG","4269"]],
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","26915"]]
$ ogrinfo 128Resolution.shp
INFO: Open of `128Resolution.shp'
using driver `ESRI Shapefile' successful.
1: 128Resolution (Polygon)
On Fri, Feb 15, 2008 at 11:31 AM, Fawcett, David
<David.Fawcett at state.mn.us> wrote:
This looks like a projection issue.
If you run ogrinfo on the tile index what do you get?
How about if you run gdalinfo on one of the image tiles?
Sent: Friday, February 15, 2008 10:23 AM
To: Fawcett, David
Projection Issue in MapServer
Sure thing, thanks David.
I am using MapServer for Windows version 2.2.6,
I have attached both again for you.
Thanks,
Rob
On Fri, Feb 15, 2008 at 10:47 AM, Fawcett, David
Robert,
Can you post the text of your map file
and the version of MapServer that
you are using?
I also didn't see the .png attachment
come through.
David.
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Robert Hyx
Sent: Friday, February 15, 2008 9:30 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Strange
Hello Everyone,
I am having a strange problem with
mapserver and reprojecting on the
fly. I have some imagery in mapserver
that has been processed but is
still kept in its native projection
26915, and when I use the
PROJECTION
"init=epsg:4326"
END
in the header (above the paths of the
shape files)
and I use
PROJECTION
"init=epsg:26915"
END
in each layer (above the path of each
shape file), I get another version
of the imagery over on the other side of
the world in addition to the
normal version of the imagery that
appears in the correct place.
I have attached a png of what the
imagery that appears in the incorrect
place looks like. Any help would be
greatly appreciated.
Thanks,
Robert
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080215/5ef5d081/attachment.html
