[mapserver-users] MapServer consuming 100% CPU
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Thu Feb 21 08:12:12 EST 2008
It is because Mapserver cannot use any attribute indexes on the DBF.
Put your shapefile in a spatial database like PostGIS I would suggest and
create attribute indexes.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Paul Spencer <pspencer at dmsolutions.ca>
Naar: Desarrollo Desarrollo <devmapserver at gmail.com>
Cc: mapserver-users at lists.osgeo.org
Onderwerp: Re: [mapserver-users] MapServer consuming 100% CPU
Datum: 21/02/08 11:09
> See:
> http://mapserver.gis.umn.edu/docs/howto/mapfiletuning
> http://mapserver.gis.umn.edu/docs/howto/optimizevector
> http://mapserver.gis.umn.edu/docs/howto/tileindex
> Cheers
> Paul
> On 21-Feb-08, at 2:56 AM, Desarrollo Desarrollo wrote:
> > Hi,
> > I am developing an application with MapServer v2.2.7 with
> > Apache on Windows XP, but I have a serious problem, below I
> > describe it:
> > Using Navteq demo maps from Paris, the Streets.shp have around
> > 500000 line strings features, when mapserver renders the layer
> > without using DBF data (only draw lines) everything is OK and fast,
> > but when mapserver needs to access to the DBF to render labels or
> > use expressions to filter data, mapserver starts to consuming 100%
> > CPU and nothing is rendered after to spends a long time.
> > Using Teleatlas demo maps for a medium city of Spain, the Street.shp
> > with around 11000 line strings features doesn't show any trouble and
> > mapserver renders the images OK and fast even accessing to DBF to
> > render labels
> > Could somebody help me with this problem? Why does it happen? How do
> > I solve it?
> > Thank you very much.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://www.dmsolutions.ca/
