WFS request options
nelson guda
nelson.guda at GMAIL.COM
Fri Jan 4 17:23:46 EST 2008
Josh, Let's see...
> What's your template (query.html) look like?
- well, there is likely the problem. I don't have a good idea of
exactly what the query template is supposed to look like. I used
this from the tutorial, but I imagine that it is not correct:
<tr>
<td>[lrn]</td>
<td>[ID]</td>
<td>[STATE]</td>
<td>[FOREST]</td>
<td>[ACRES]</td>
</tr>
Any resources for better explanations?
thanks,
nelson
Thanks for the proj suggestions. I'll look into it.
>> PROJECTION
>> "init=epsg:54004"
>> END
> I am assuming this projection is what is defined in your proj file
> by what is sometimes referred to as 'world mercator'. If so, you
> may be interested in using this projection instead (won't make a
> huge difference in the states, but it is more accurate still)
> http://spatialreference.org/ref/user/google-projection/
> Cheers,
> -Josh
