demo map
mapserver at UNIXPLANET.BIZ
Wed Jan 9 16:26:55 EST 2008
Thanks for help,
but stillthe same problem with workshop.zip in forwarded url, actually
the index.html is identical to the one I had before.
Pericles S. Nacionales wrote:
> I probably should have read your original post thoroughly in the first
> place. The demo was updated to work with version 5.0, making it
> unusable for 4.x. The 4.x compatible demo is still available at
> http://maps.dnr.state.mn.us/mapserver_demos/workshop.zip.
> Sorry for the confusion.
> -Perry
> MapServer wrote:
>> I just downloaded the demo from the following url and it suppose to
>> work with version 4:
>> http://mapserver.gis.umn.edu/download/current/
>> I changed the first part as you directed, but there is no hidden
>> input for map_web, so I just added it
>> but still the same error.
>> any idea ?
>> is there any demo based on php ?
>> Thanks
>>> Sounds like you have an older version of demo. Edit the index.html
>>> and replace the following lines:
>>> <select name="map_web_template" size="1">
>>> <option value="itasca_basic.html"> Basic Application
>>> <option value="itasca_adds_scalebar.html"> --
>>> Adds second scalebar
>>> <option value="itasca_adds_pan.html"> -- Adds pan
>>> controls
>>> <option value="itasca_adds_frames.html"> -- Adds
>>> frames
>>> <option value="itasca_adds_dhtml.html"> -- Adds
>>> dhtml rubber-band box
>>> </select>
>>> with these:
>>> <select name="map_web" size="1">
>>> <option value="template itasca_basic.html"> Basic Application
>>> <option value="template itasca_adds_scalebar.html">
>>> -- Adds second scalebar
>>> <option value="template itasca_adds_pan.html"> --
>>> Adds pan controls
>>> <option value="template itasca_adds_frames.html">
>>> -- Adds frames
>>> <option value="template itasca_adds_dhtml.html">
>>> -- Adds dhtml rubber-band box
>>> </select>
>>> Also change these lines:
>>> <input type="hidden" name="map_web_imagepath"
>>> value="/ms4w/tmp/ms_tmp/">
>>> <input type="hidden" name="map_web_imageurl" value="/ms_tmp/">
>>> to these:
>>> <input type="hidden" name="map_web" value="imagepath
>>> /ms4w/tmp/ms_tmp/">
>>> <input type="hidden" name="map_web" value="imageurl /ms_tmp/">
>>> Look for RFC-31 for more info.
>>> Cheers!
>>> -Perry
>>> MapServer wrote:
>>>> Hello
>>>> I have installed map server but while I am trying to test the demo
>>>> map I get following error :
>>>> Content-type: text/html msReturnPage(): Unable to access file. set
>>>> in index.html
>>>> and also I noticed that png files have been created in root of demo
>>>> with following names:
>>>> [root at firstone workshop-5.0]# ls -la set*
>>>> -rw-r--r-- 1 apache apache 25840 Jan 9 11:57 set in
>>>> -rw-r--r-- 1 apache apache 422 Jan 9 11:57 set in
>>>> -rw-r--r-- 1 apache apache 353 Jan 9 11:57 set in
>>>> -rw-r--r-- 1 apache apache 163 Jan 9 11:57 set in
>>>> here is my changes to index.html located in workshop-5.0
>>>> // EDIT THE NEXT 2 LINES TO MATCH YOUR SETUP
>>>> var snippet = "IMAGEPATH '/var/www/html/workshop-5.0/tmp/'";
>>>> snippet += " IMAGEURL '/tmp/'";
>>>> snippet += " TEMPLATE " + template;
>>>> document.demo.map_web.value = snippet;
>>>> <input type="hidden" name="map"
>>>> value="/var/www/html/workshop-5.0/itasca.map">
>>>> <input type="hidden" name="program" value="/cgi-bin/mapserv">
>>>> <input type="hidden" name="root"
>>>> value="/var/www/html/workshop-5.0/">
