demo map
    mapserver at UNIXPLANET.BIZ
    Wed Jan  9 13:32:34 PST 2008
my bad, you are right , there is one for version 4 and I was using
version 5.
Thanks for help
MapServer wrote:
> Thanks for help,
> but stillthe same problem with workshop.zip in forwarded url, actually
> the index.html is identical to the one I had before.
> Pericles S. Nacionales wrote:
>> I probably should have read your original post thoroughly in the
>> first place.  The demo was updated to work with version 5.0, making
>> it unusable for 4.x.  The 4.x compatible demo is still available at
>> http://maps.dnr.state.mn.us/mapserver_demos/workshop.zip.
>> Sorry for the confusion.
>> -Perry
>> MapServer wrote:
>>> I just downloaded the demo from the following url and it suppose to
>>> work with version 4:
>>> http://mapserver.gis.umn.edu/download/current/
>>> I changed the first part as you directed, but there is no hidden
>>> input for map_web, so I just added it
>>> but still the same error.
>>> any idea ?
>>> is there any demo based on php ?
>>> Thanks
>>>> Sounds like you have an older version of demo.  Edit the index.html
>>>> and replace the following lines:
>>>>      <select name="map_web_template" size="1">
>>>>        <option value="itasca_basic.html"> Basic Application
>>>>        <option value="itasca_adds_scalebar.html">   --
>>>> Adds second scalebar
>>>>        <option value="itasca_adds_pan.html">   -- Adds
>>>> pan controls
>>>>        <option value="itasca_adds_frames.html">   -- Adds
>>>> frames
>>>>        <option value="itasca_adds_dhtml.html">   -- Adds
>>>> dhtml rubber-band box
>>>>      </select>
>>>> with these:
>>>>      <select name="map_web" size="1">
>>>>        <option value="template itasca_basic.html"> Basic Application
>>>>        <option value="template itasca_adds_scalebar.html">
>>>>   -- Adds second scalebar
>>>>        <option value="template itasca_adds_pan.html">
>>>>   -- Adds pan controls
>>>>        <option value="template itasca_adds_frames.html">
>>>>   -- Adds frames
>>>>        <option value="template itasca_adds_dhtml.html">
>>>>   -- Adds dhtml rubber-band box
>>>>      </select>
>>>> Also change these lines:
>>>>      <input type="hidden" name="map_web_imagepath"
>>>> value="/ms4w/tmp/ms_tmp/">
>>>>      <input type="hidden" name="map_web_imageurl" value="/ms_tmp/">
>>>> to these:
>>>>      <input type="hidden" name="map_web" value="imagepath
>>>> /ms4w/tmp/ms_tmp/">
>>>>      <input type="hidden" name="map_web" value="imageurl /ms_tmp/">
>>>> Look for RFC-31 for more info.
>>>> Cheers!
>>>> -Perry
>>>> MapServer wrote:
>>>>> Hello
>>>>> I have installed map server but while I am trying to test the demo
>>>>> map I get following error :
>>>>> Content-type: text/html msReturnPage(): Unable to access file. set
>>>>> in index.html
>>>>> and also I noticed that png files have been created in root of
>>>>> demo with following names:
>>>>> [root at firstone workshop-5.0]# ls -la set*
>>>>> -rw-r--r-- 1 apache apache 25840 Jan  9 11:57 set in
>>>>> -rw-r--r-- 1 apache apache   422 Jan  9 11:57 set in
>>>>> -rw-r--r-- 1 apache apache   353 Jan  9 11:57 set in
>>>>> -rw-r--r-- 1 apache apache   163 Jan  9 11:57 set in
>>>>> here is my changes to index.html located in workshop-5.0
>>>>>  // EDIT THE NEXT 2 LINES TO MATCH YOUR SETUP
>>>>>         var snippet = "IMAGEPATH '/var/www/html/workshop-5.0/tmp/'";
>>>>>         snippet += " IMAGEURL '/tmp/'";
>>>>>         snippet += " TEMPLATE " + template;
>>>>>         document.demo.map_web.value = snippet;
>>>>> <input type="hidden" name="map"
>>>>> value="/var/www/html/workshop-5.0/itasca.map">
>>>>>       <input type="hidden" name="program" value="/cgi-bin/mapserv">
>>>>>       <input type="hidden" name="root"
>>>>> value="/var/www/html/workshop-5.0/">
More information about the MapServer-users
