[mapserver-users] Compiling Issues: Ubuntu 8.04
Matthew Pettis
matthew.pettis at gmail.com
Fri Jul 18 09:12:34 EDT 2008
Hi Guillaume, Milo,
Thanks for the replies... please see below
MIlo:
Ah!
I faced this one on debian yesterday! Thanks to great help on the irc
channel I can help ou with a solution, aint life great?
You say proj_api.h is in that directory, but how about libproj.a/libproj.so?
Did you run the ./configure, make , make install for proj?
If you did
You may need to run:
ldconfig /usr/include
proj_api.h is in /usr/include/ while libproj.a/libproj.so are in
/usr/lib... i didn't build the libproj.* libraries myself, but
downloaded them via synaptic -- do i need to do a manual build?
Guillaume:
On Fri, Jul 18, 2008 at 2:05 AM, Guillaume Sueur
<guillaume.sueur at neogeo-online.net> wrote:
> did you add your lib path to /etc/ld.so.conf and run ldconfig after proj
> install ?
> Guillaume
> Matthew Pettis a écrit :
>> Hi,
>> I am compiling MapServer from source because I want to include
>> fastcgi... anyway, I've fixed most of the compile issues, but I can't
>> get past the following:
>> configure: checking whether we should include PROJ.4 support...
>> configure: error: "Could not find proj_api.h or libproj.a/libproj.so
>> in /usr/include/."
>> However, I verified that /usr/include/proj_api.h does exist, so I'm a
>> bit confused... any suggestions?
>> Thanks,
>> Matt
answer: no, because like I wrote to Milo, I did a synaptic install of
the proj library, not a manual build... can i still edit it after
doing a synaptic install? my ld.so.conf file looks like this
currently:
include /etc/ld.so.conf.d/*.conf
is this what it should look like?
Thanks,
Matt
It is from the wellspring of our despair and the places that we are
broken that we come to repair the world.
-- Murray Waas
