[mapserver-users] Compiling Issues: Ubuntu 8.04
Matthew Pettis
matthew.pettis at gmail.com
Fri Jul 18 10:03:02 EDT 2008
Thanks Daniel, Guillaume,
Daniel: you are correct in that I configured with
"--with-proj=/usr/include", and also tried "--with-proj=/usr/lib". I
will try tonight with your suggestion.
Thanks!
Matt
On Fri, Jul 18, 2008 at 8:23 AM, Daniel Morissette
<dmorissette at mapgears.com> wrote:
> Is it possible that you configured using "--with-proj=/usr/include"? You
> should use "--with-proj=/usr" only and the configure script should take care
> of looking in the right subdirectory for each file.
> Daniel
> Matthew Pettis wrote:
>> Hi,
>> I am compiling MapServer from source because I want to include
>> fastcgi... anyway, I've fixed most of the compile issues, but I can't
>> get past the following:
>> configure: checking whether we should include PROJ.4 support...
>> configure: error: "Could not find proj_api.h or libproj.a/libproj.so
>> in /usr/include/."
>> However, I verified that /usr/include/proj_api.h does exist, so I'm a
>> bit confused... any suggestions?
>> Thanks,
>> Matt
> Daniel Morissette
> http://www.mapgears.com/
It is from the wellspring of our despair and the places that we are
broken that we come to repair the world.
-- Murray Waas
