[mapserver-users] ECW Problems
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Jul 18 10:50:01 EDT 2008
On 18-Jul-08, at 9:21 AM, Derek Bain wrote:
> Hi
> I cannot get ecw files to work in Mapserver. I have updated my map
> file (see below).
> Is there any configuration that I have to do to enable this or is
> ecw by default. I am using ms4w beta 5..2.
> My client is WorldWind and I am using the "Import to WMS Url Layer"
> option. It would appear that MapServer fails when processing the map
> file. Are there any options to set to enable a debug console window
> when processing the map file.
> I have checked that my ecw file is georeferenced and it is.
> Thanks
> Derek
> LAYER
> NAME TestECWLayer
> TYPE RASTER
> STATUS ON
> DUMP TRUE
> DATA "C:/Progra~1/ms4w/Apps/All_Data/data/testfile.ecw"
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wms_title" "TestECWLayer"
> "wms_abstract" "TestECWLayer abstract goes
> here ...."
> "wms_srs" "EPSG:4326"
> "wms_name" "TestECWLayer"
> "wms_format" "image/png image/jpeg"
> "wms_extent" "-88.9803405 30.2175328
> -88.9755868 30.2216604"
> "wms_onlineresource" "http://localhost:8082/cgi-bin/mapserv.exe?map=C:/Progra
> ~1/ms4w/apps/All_Data/ECW_Test.map"
> END
> CLASS
> NAME "TestECWLayer"
> COLOR 255 0 0
> END
> END
Hello,
I have made some notes for you below to assist you with your ECW issue:
1) MS4W (and its underlying GDAL library) comes ready to use ECW data
by default. To verify this, execute /ms4w/setenv.bat at the
commandline, and then execute "gdalinfo --formats" to
see if ECW is supported, such as:
>gdalinfo --formats
Supported Formats:
VRT (rw+): Virtual Raster
GTiff (rw+): GeoTIFF
ECW (rw): ERMapper Compressed Wavelets
ADRG (rw+): ARC Digitized Raster Graphics
2) Now that you have established that your local build has ECW support,
now use the gdalinfo command on your data to get some basic info
on your ecw file, such as:
>gdalinfo image1.ecw
Driver: ECW/ERMapper Compressed Wavelets
Files: image1.ecw
image1.ecw.aux.xml
Size is 7966, 8274
Coordinate System is:
PROJCS["LCC E008",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",49],
PARAMETER["standard_parallel_2",77],
PARAMETER["latitude_of_origin",49],
PARAMETER["central_meridian",-95],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (2878735.262000000100000,995462.974999999980000)
Pixel Size = (30.000000000000000,-30.000000000000000)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( 2878735.262, 995462.975) ( 52d35'49.00"W, 48d59'18.47"N)
Lower Left ( 2878735.262, 747242.975) ( 54d36'32.41"W, 47d13'6.98"N)
Upper Right ( 3117715.262, 995462.975) ( 50d 6'40.01"W, 47d37'48.85"N)
Lower Right ( 3117715.262, 747242.975) ( 52d 9'36.52"W, 45d55'23.39"N)
Center ( 2998225.262, 871352.975) ( 52d22'14.82"W, 47d27'4.74"N)
Band 1 Block=7966x1 Type=Byte, ColorInterp=Red
Overviews: arbitrary
Band 2 Block=7966x1 Type=Byte, ColorInterp=Green
Band 3 Block=7966x1 Type=Byte, ColorInterp=Blue
3) Next step is to create a small test mapfile with only one layer,
for that
ecw file. For the EXTENT parameter you can use the lower left and
upper right
coordinates listed in your gdalinfo response, such as:
# Start of map file
NAME ecw-test
STATUS ON
SIZE 600 400
EXTENT 2878735.262 747242.975 3117715.262 995462.975
UNITS METERS
SHAPEPATH "../data"
# Start of layer definitions
LAYER
NAME "ecw-image"
TYPE RASTER
STATUS DEFAULT
DATA "image1.ecw"
END # Layer
END # Map File
4) You can test your tiny mapfile with MapServer's "shp2img" utility
that is part of
MS4W. (make sure you execute /ms4w/setenv.bat beforehand).
shp2img will
create a map image file or return a MapServer error at the
commandline.
You can use this MapServer error to track down the problem in your
mapfile.
Here is an example shp2img command to show you how to see
debugging information
with shp2img:
>shp2img -m ecw.map -o test.png -map_debug 3
msDrawRasterLayerLow(ecw-image): entering.
msDrawMap(): Layer 0 (ecw-image), 0.220s
msDrawMap(): Drawing Label Cache, 0.000s
msDrawMap() total time: 0.220s
msSaveImage() total time: 0.010s
In the above test case a "test.png" image file was created in the
same
directory as my "ecw.map" file.
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080718/37ff0d0f/attachment-0001.html
