[mapserver-users] From shapefiles to PostGIS, MAPServer
Richard Duivenvoorde
rdmailings at duif.net
Sun Mar 9 11:14:09 EDT 2008
Hi Bruno,
I googled this pages for you :-) :
http://mapserver.gis.umn.edu/docs/reference/vector_data/postgis
here is another one: see the PostGIS DB section:
http://umn.mapserver.ch/index_en.php
Note: for views (tables?) you should have one unique column, and use it
in your query using the 'unique'-keyword as shown below (which comes
from a postgis/mapserver/debian cookbook I wrote a couple of days back
http://www.duif.net/postgis ):
layer
name 'world'
metadata
"wms_title" "postgis world"
"wms_srs" "epsg:4326"
end
status default
template "dummy"
connectiontype postgis
connection "host=localhost dbname=mygisdb password=**** user=richard"
data 'the_geom from mygisdb using unique gid using srid=4326'
type polygon
class
color 255 0 0
outlinecolor 192 192 192
end
end
Regards,
Bruno Ripa wrote:
> Hallo guys,
> i have worked on a Plone project handling a gis (using PrimaGIS
> product); it used shapefiles to render the gis.
> Now i have translated all shapefiles into postgis and i can check it is
> correct using QGis (under MacOSX).
> The question is: where can i get some 'real' examples of how to create
> Mapserver map file to let it read postgis data ? I have made some
> 'blind' experiments, but it's not a good way to do things like that :D
> In particular it would be nice to get map file sections documentation.
> P.s.: the project runs on Debian.
> Thanks in advance
