[mapserver-users] Matching .TFW file with EXTENT parameter?
kreshna_iceheart at yahoo.com
Mon Nov 3 02:19:32 EST 2008
I have a map file with following MapExtent parameter:
EXTENT 106.335006 -6.896956 107.315811 -5.983994
Recently, I got a TIFF file without coordinates. I plan to use the TIFF file with my map. Thus, I'm supposed to create a .TFW file using text editor, am I correct?
Problem is: I'm not sure what parameter to be put in the .TFW file. Here is the parameters I put in my TFW file so far:
1.000
0.000
0.000
-1.000
106.335006
-5.983994
And I failed to show the raster on my map.
Please note that I am merely guessing. It seems that the fifth and the sixth like of the TFW should be the leftmost and rightmost number of my EXTENT parameter, respectively, but I have no idea what the first four lines are for.
Based on EXTENT parameter above, what the correct .TFW values should be? Many thanks,
-Kresh
