[mapserver-users] Problem with Python Mapscript / Projection
(MS4W)
Umberto Nicoletti
umberto.nicoletti at gmail.com
Wed Nov 5 02:33:53 EST 2008
make sure that the user running apache can read the /usr/share/proj/epsg file.
If permissions seem ok then it could be a problem with SELinux or
apparmor, depending on your platform.
Umberto
On Wed, Nov 5, 2008 at 6:12 AM, Christian Jauvin <cjauvin at gmail.com> wrote:
> Hi,
> I get a "MapServerError: msProcessProjection(): Projection library
> error. Permission denied" error while using Python/MapScript (MS4W
> 2.3, MapServer 5), after having included a
> PROJECTION
> "init=epsg:XXXX"
> END
> directive in a mapfile layer. I guess that it has something to do with
> an Apache permission to execute a binary somewhere..
> This is I think the first time I can't find an answer to a MS problem
> simply by googling, so I try it here, in hope that someone will be
> able to help.
> Thank you in advance,
> Christian
> mapserver-users at lists.osgeo.org
