[mapserver-users] Get the actual mode of the map
Rui Gomes
ruijgomes at gmail.com
Fri Nov 7 12:13:44 EST 2008
Thanks.
It is Working. I do'n no why, but i try it [mode] before but the
browser don't replace then.
Thanks again.
2008/11/7 Steve Lime <Steve.Lime at dnr.state.mn.us>:
> Assuming you set it on the call to MapServer it should be simply [mode] on the
> way out. The only possible values you can get at via a template are browse
> or one of the various query modes. Browse is the default so for those templates
> you know mode=browse. For queries you have to explicitly set mode so [mode]
> should work.
> Steve
>>>> "Rui Gomes" <ruijgomes at gmail.com> 11/06/08 11:51 PM >>>
> Good Morning...
> I try to find a substitution string to get the current mode of the map
> and i can't find it.
> There is some way to know what is the mode?
> Thanks
> Rui Gomes
> mapserver-users at lists.osgeo.org
Rui Gomes
