[MAPSERVER-USERS] installation problem
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Nov 7 19:34:22 EST 2008
veera_s wrote:
> hi all
> first i extracted ms4w_2.3.0.zip in the C drive
> its installed properly
> but apache didnt run even i tried /ms4w/apache-install.bat
> so i removed the ms4w folder from c drive without trying
> /ms4w/apache-uninstall.bat
> atlast i tried and removed apache ms4w server service from the service
> now again iam tring to extract the ms4w_2.3.0.zip in the C drive
> but it is displaying error as cannot create ms4w\apache\bin\httpd.exe access
> is denied
> other than c drive it is extracting in remaining drives properly without
> showing error
> plz tell me why it happens
If you are getting "ms4w\apache\bin\httpd.exe access denied" errors and
you have already removed the apache service, then you can now delete the
entire /ms4w directory...and then extract again.
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
